Home Forum Ask A Member Starter Rope for 1947 Sea King 5 Horse
  • #290991
    Hello,
    I will appreciate if anyone can help me with the type, diameter of starter rope to
    replace the original rope with a wire inner.
    thanks in advance!
    #290994
      The biggest challenge is finding a way to secure the rope,
      as the wire cable ropes had a “hook” on the end, and did
      not have clearance issue.
      Some times tying a knot in a nylon rope and not having
      it rub is a problem.
      However way you come up with, you’ll probably end up
      using a smaller diameter rope than the original.
      #290995
      dave-bernard
        use a needle bearing like mercury did
        #290999
        Hello,
        So I understand that I may have some difficulty attacking the new starter rope from your replies. Also mentioned that maybe need to use a smaller diameter rope.What diameter rope should I use and should it be nylon?
        Thanks
        #291001
        crosbyman
          Canada Member - 2 Years
          5/32 should do…   maybe you can build a hook and attach/crimp  it to the rope  followed with a few drops of  crazy glue to secure it
          get good rope  from small engine repair shops  70-75 inches or less should do
          #291005
            Use a “Hard Braid” nylon rope, not the soft floppy kind.
