Home Forum Ask A Member Starting Ab-25 Johnson motor
  • #178865
    muddog2
      Well, I went out this morning and put the motor in a barrel so I could see if the water pump worked. I cleaned it last week. I flooded the engine right off. Took out plugs, closed petcock valve, and pulled 8 times. II put the plugs back in and tried to start the motor with the carb set on fast and the armature handle over the carb in the center. It sputtered a few times no more than a couple seconds. I took the plugs out and changed gap to 20. Someone told me to set the gap to 30. With the petcock valve off I pulled 8 or 9 times and it ran a few seconds each time. I opened the petcock valve and after a couple of pulls it started. Had needle valve 1/2 turn out. Seems to run rough at slow speeds. It backfired a couple of times also. Good news is the water pump works. Now I just need to play around with this motor until I learn how to operate it. Here is a link to video of it running today. https://www.facebook.com/profile.php?id=100000043664975
      Thanks again for all the help
      Robert Clark
      #178871
      muddog2
        Went out after supper and I got the needle set. Motor ran like a champ. in slow and fast setting. Ready for the lake next weekend.
        #178897
          • This reply was modified 5 years, 5 months ago by Tubs.
          #178944
          muddog2
            Yep!
