Home Forum Ask A Member Starting Outboard with 1/2″ drill
  • #202052
    jim-moffatt
      Is there any way to connect a 1/2 drill through a one-way drive to the flywheel nut for starting a motor?
      I think, without the drive, if the motor starts it would rip the drill out of my hands. My motor is a 24 cu in 16 hp.
      Can some rewind be adapted to do this or can a drive be purchased?
      #202053
        • This reply was modified 4 years, 11 months ago by Tubs.
        • This reply was modified 4 years, 2 months ago by Tubs.
        #202065
          Be sure to use a corded drill as a cordless drill will stop instantly when the trigger is released and get wrenched out of your hands when the motor starts. The one way clutch is a good idea to.
          #202075
            Don’t use an impact wrench. It will beat away at the flywheel nut and over-torque it.
            #202077
            fleetwin
              Yes, I would be concerned about over torqueing the flywheel nut also, even with a conventional drill…
              #202081
              Ken Smith
                I haven’t received my April Outboarder issue. Who would I contact about this Thanks Ken
                www.kenadianoutboards.com
                #202150
                  #202161
                  Ken Smith
                    Thanks Tubs. I sent an email. What a time to be missing an issue!
                    #202332
                    jim-moffatt
                      thanks Tubs I just ordered a ratchet!
                      #202342
