Home › Forum › Ask A Member › Stator 5.5hp ’55 johnson cd10
- This topic has 11 replies, 5 voices, and was last updated 5 years, 10 months ago by
JACQUES.
August 6, 2020 at 1:07 pm #210985
How is the stator plate removed?
August 6, 2020 at 1:18 pm #210986screws…. remove all the ones on the plate ( 2 long ones on the coils 2 short ones see #1 #2 ) disconnect mechanical parts
pull up
August 6, 2020 at 2:26 pm #210995Anonymous
Thank you. had already done that including removing point rotor, and coils. Wont budge maybe not enough strength, but concerned about using pry bar under it. Any additional thoughts? Thanks again for your help.
August 6, 2020 at 2:27 pm #210996Anonymous
August 6, 2020 at 2:33 pm #210997Does the plate swivel back and for normally while in place?
If so, it’s not binding on the power head. Perhaps
you took out a couple of the wrong screws?Prepare to be boarded!
August 6, 2020 at 4:29 pm #211009Those four screws are all that hold it down. I should lift off with ease by only fingertip pull, no forcing required. If it doesn’t swivel back and forth, perhaps it is corroded in place. How does the rest of it look? Lots of corrosion?
August 6, 2020 at 4:38 pm #211014Anonymous
I see a circular clip at the bottom of the plate dose this have to be removed? all the screws have been removed. 1 long one and 2 shorter for each coil. Tried a 3 legged puller with mild pressure and tapped several times.Nada.
August 6, 2020 at 4:58 pm #211018If all you have removed are the 3 screws on each coil, the plate won’t come off. There are 2 others to remove – see the picture crosbyman included in his post above or see the enclosed pic from my ’54 CD-11, essentially the same as your motor. There is no clip below the plate – there is a support ring which won’t come off until you remove the magneto plate. And don’t use a puller on that plate!!
"Every time you remove a broken or seized bolt an angel gets his wings."August 6, 2020 at 5:42 pm #211024suggest you read the following
http://www.leeroysramblings.com/johnson_magneto.htm
if you are going to pull the plate may as well redo coils (inspect closely for cracks and burn marks) , plug wires (metallic 7mm) etc…
lots of utubes on omc magnetos
August 7, 2020 at 10:01 am #211070Anonymous
Thank you. Went back and looked found 1 screw hidden by points on each side, removed same. All good lifted right off. Thanks again.
