Home Forum Ask A Member Stevens tester
Viewing 2 posts - 21 through 22 (of 22 total)
  • #255267
    Dave Willacy
      what voltage did you finally set yours to?
      #255268
      Dave Willacy
        Right!  The manual actually says to set the current first with the leads connected together, then test the coil at that setting.  If it sparks fine the coil is “good”.  Personally I like to see at what current it starts to fire and assess that reading against the “norm” in the book. Either way its important to have a standard voltage applied to achieve the current given the coils resistance.  Just me being picky.
