Home Forum Ask A Member Struggling with drum and pulley steering
Viewing 10 posts - 11 through 20 (of 29 total)
  • #80226
    stanley
      Both cables come of the top of the steering wheel drum?Make sure the motor swivels easily when not hooked to cables.
      #80227
      mgsolakis
        Okay that could be the problem in the diagram it looks like the wire comes off the bottom of the inside drum. So both should come off the top of the drum?
        #80230
        dave-bernard
          DEPENDS ON WHERE THE STEERING IS HOOKE UP. IF IN THE FRONT THAT IS TRUE UNLESS YOU RUN DOWN ONE SIDE ONLY. COMES OFF THE BOTTOM IF THE HOOKUP IS ON THE REAR OF THE MOTOR LIKE MOST RACE MOTORS.
          #80240
          mgsolakis
            The wires run down both sides of the boat, the drum is on the steering wheel under the dash just to clarify.
            #80243
              With one cable on each side of the boat, both cables need to wind off the top of the drum.
              #80246
                You’re in for a BIG surprise if you get them backwards . . . 😮
                #80273
                nj-boatbuilder57
                  I don’t mean to hi-jack the thread, but can anyone tell me what size / lay / material the cable should be? I’ve been using rope (Yeah, I know…), and I want to re-do it properly.
                  #80282
                    Typically use vinyl coated wire rope (cable). Diameter size depends on what size pulleys you are using.
                    #80283
                    nj-boatbuilder57
                      ’57 Johnson 35HP…the pulleys look like they’re about 2" diameter, but the groove isn’t very big at all….
                      #80285
                        Take one of the pulleys with you to a supply house and do a trial fit. Maybe 3/16" diameter.
