Home › Forum › Ask A Member › Stubborn Flywheel, Gale 40 hp
Viewing 10 posts - 41 through 50 (of 51 total)
  • #184110
      Nice “How to” lesson. Good job well done.
      #184136
      outboardnut
        All I can say is WOW
        #184137
        squierka39
          Did you see any reason for it being so stuck?
          #184152
            None Whatsoever! If anyone had greased it putting it back together that
            got burnt away with the several “torchings”.
            The coils appeared to be original, so maybe the sucker was never
            off in the last 56 years!
              Good for you, I admire your persistence for sure. I’m sure a decent flywheel should be easy to find, unless that Gale flywheel is unique for some reason…
              Let me know if you don’t a flywheel easily, would be happy to help you search….
              #184223
                Fleetwin, thanks for the offer. I have a $30 flywheel coming. The 62 Gale flywheel part number
                shows the same as the somewhat later Evinrude and Johnson 28 and 40 hp.
                I have one from a 28 hp coming. Looks the same in the photo, other than it has
                a ring gear. My manual start one did not. Presume that’s not a problem.
                  28p had a ring gear to accept their accessory electric starting kit.
                  #184252
                    Not sure if my Gale is adaptable to electric start, but if so, with the new flywheel
                    coming, I, or someone else, will have a head start!
                    Phil Budne
                      There are “40DExx” models in the Gale manual for 1960-1963:
                      http://www.richardlpaquette.ca/GaleProducts1951-1963ServiceManual.pdf
                      I’m wondering if the 40DGxx models are the “Sovereign” models
                      http://www.omc-boats.org
                      #184272
                        “D” = “Deluxe”, a relic term left over from the days when they made a “Standard’ model
                        “E” = “Electric” Start
                        “G” = “Generator”, Electric start, plus has a factory-installed generator kit.
