Home › Forum › Ask A Member › Stuck glass sediment bowl
Any good tricks for removing a stuck glass sediment bowl?It’s on a 54 RD15 carb.
I’d start out using a hair dryer set on high, and gently tap it with a soft hammer.
remove it with the mounting and soak it in warm water for a few minutes or try some carb cleaner around the rim …. that should loosen things up
careful with that hammer !!
Crosbyman is right! Try a good soak in piping hot water. Any light taps should be with a tiny rubber mallet or wood.
Thanks to all.Got it off using heat,carb cleaner and a few light taps with a rawhide hammer.
