Home › Forum › Ask A Member › Substituting Old Condensers With Modern Capacitors
  • #170957
      The question keeps surfacing about what to do about old condensers which need replacing and are NLA. Well, a few years ago a club member went to great lengths to figure out which modern capacitors will work in our old magnetos. What he came up with was these Vishay axial capacitors available from Digi-Key and other electrical suppliers.
      Here’s a few snips of the original post explaining the part numbering system.
      VPN1
      VPN2
      VPN3
      VPN4
      Thanks again Jeff!
      And here’s some links to Digi-Key for commonly used caps in 0.10, 0.15 and 0.22 uF ratings. You can choose your country in the top right corner.
      https://www.digikey.ca/products/en?x=23&y=19&lang=en&site=ca&KeyWords=bc2607-nd
      https://www.digikey.ca/products/en/capacitors/film-capacitors/62?k=bc2608-nd
      https://www.digikey.ca/product-detail/en/vishay-bc-components/MKP1839422084HQ/BC2609-ND/2260507
      Caps can be wired in parallel to arrive at the required uF (microfarad) rating for your motor. For example, if your mag need a cap rated at .30 uf, two .15’s can be used in parallel if a .30 cap is unavailable.
      Vishay produces these caps with different voltage ratings but I’ve only used ones with an 850 volt rating. A smaller cap with a lower voltage rating might work to but I’m not sure.
      DSC01376-1
      • This topic was modified 7 years, 6 months ago by Mumbles.
      #170966
        And to help you choose which replacement cap to use in your oldie, here are some tables showing original uF ratings which another club member graciously compiled for us to use. Maybe Garry? Thanks!
        Caps_table1
        Merc-Caps_Table2
        Caps_table3
        Caps_table4-Evinrude
        Caps_table5
        • This reply was modified 7 years, 6 months ago by Mumbles.
        #170993
          Jim,
          Remember speaking to Vishay & a requirement is ALL caps must be rated “High Quality’ HQ suffix to live in a mag. Still have the paperwork rat-holed somewhere!!
          Jeff
          #171202
            You’re welcome – I still haven’t found the value for the Evinrude Sportfour – Does anyone know ? ? ? [/size][/color]
            #171480
            JOHN D.
              I found out today that the 400 volt caps don’t last very long in the Bendix Scintilla magnetos. Five minutes max.
              #171481
              JOSEPH BRINCAT
                It was through Jeff’s expertise that I and all of us realized that benefit of using these modern Vishay high quality capacitors in our motors. It was at least 3 or 4 years ago that he investigated the properties of the various modern cap and identifies the correct properties suitable for magneto service. I don’t begin to understand all the electronic specs ,but I remember that there was a lot mote to it than just the capacitance and voltage rating. Thanks Jeff
                #171580
                mercuryman
                  How did the old condensers work so well. Just metal foil and paper rolled tight and stuffed in a can ?
                  #171651
                  JOSEPH BRINCAT
                    The old caps worked just fine when they were new. Problem is that they have a shelf life, even when not in use. The paper and wax insulation breaks down and absorbs moisture over time. Just ask anyone that works on old radios or TV’s .. first thing that they have to do to bring an old set back to life is replace all the old caps.
                    #171711
                      Well my order of Vishay Caps came in today. I kept adding to cart to get it over 100USD to get free shipping. Should be good for Caps for a while.
