Home › Forum › Ask A Member › Suzuki 65 hp twin
  • #184249
    amuller
      Anybody have any experience with these? The one I was looking at seems to be a 1979. Truly a “big twin!” What intrigues me about it is the ignition system. Only one coil with a double ended secondary (I presume) and one primary wire. It seems to be a “wasted spark” ignition that fires both plugs every 180 degrees. This sort of ignition is common on 4 stroke engines but the first I’ve seen on a 2 stroke.
      #184319
        Johnson used a system like that for their alternate firing twins in the 1930s. The flywheel acted as a distributer. Half was insulated and the other half would short out the ignition wire to the cylinder that was at the bottom of the stroke so the engine would not backfire. The long bronze contacts to the flywheel hub were replaced by spring loaded carbon brushes against the flywheel in later models..
        #184328
        amuller
          I’ve read that jet skis (“Personal Watercraft”) and snowmobile engines use this type of ignition and apparently it works without backfires, etc. Hard to believe…..
          #184332
          David Stanton
            Johnson made some models in the mid to late 1970s that were something like that, having one magneto coil with two sets of spark plug wires, and two sets of points; one set of points being on each primary coil lead to ground, so when one set of points opened initiating spark, the other set had the other primary wire grounded to complete the circuit. My 1976 35 HP Johnson has this configuration.
            If one set of points goes high resistance, both cylinders die.
            amuller
              What is the purpose of the two sets of points on the Johnsons? Do both plugs fire together, so there is a spark before top center and also a spark around bottom center?
