What is the correct lubricant (oil or grease) in the swivel bracket on the 1956 Johnson 3 hp? The top of the bracket has a small hole that is stamped “OIL” next to it. But I only found grease inside the bracket during dissembly. Additionally, all of the swivel brackets on the larger engines appear to be equipped with a grease fitting. So which is the recommended lubricant?
Good question, I remember that little oiling sign, seems like it would be mighty tough to lube the swivel this way…. Trying to remember if there is a grease fitting as well. If not, and the swivel is stiff, probably best to disassemble, clean and relube…
