Home › Forum › Ask A Member › tank coatings and cork float coatings
  • #40948
    lindy46
      quote amuller:
      Item: On my can the lid was so tight that the can sides buckled while working it open. So it doesn’t seal well and will probably harden in the can if not used up promptly. Never seen this before. Anybody else encountered this?
      Alan
      I believe once opened, you’re supposed to use it all at once as the humidity in the air will cause it to cure.
      #40951
        by a spare empty paint paint can and transfer it over . stored upside down should help
