Home › Forum › Ask A Member › tank vent question on 50's era dual line tank
  • #157195
    David Stanton
      Good explanation of Pascal’s Law regarding pressure!
      Opps – somehow this double posted – maybe I double-clicked. I know how to edit, but don’t know how to delete a post I made.
      • This reply was modified 7 years, 10 months ago by David Stanton.
      #157197
      Rick Robbins
        Well to see what mine line pressure is while running I’m going to run it tomorrow with a gauge in the fuel line and see where it falls. If it’s within the limits, I’ll have to re examine my previous opinion of the float/needle and seat.
        #157219
          You cannot go by looks on those cork floats. The factory sealed them with shellac, and of coarse adding alcohol makes laquer which goes everywhere. Since todays fuels are 10 to 15% alcohol’, it is easy for a cork float to absorb enough fuel to reduce it’s buoyonts.y. If is is in super shape, bake it to get rid of the absorbed fuel and then seal it with FUEL P?OOF airplane dope, or thin Super Glue.
          #157328
          PugetSoundBoater
            if you choose to “bake it” to get the old fuel and moisture evaporated out of the float, be sure your oven door has a real strong latch and hinge., and don’t stand in front of the oven door.
            Robbie Robertson
            #157736
            Rick Robbins
              I did finally run it with a pressure gauge and it was running 5 1/2 lbs. What solved the problem was a thicker gasket, 301999, than the one I made for the casting to the main jet and the check valve in the bowl bottom. #42-62
              #157795
              outboardnut
                What temp do you bake it at?
