Home › Forum › Ask A Member › td20 crankshaft question
  • #6552
    20mercman
      I have a bunch of td20, and tn26 and 27 parts and i’m trying to turn it all into at least one running motor, I came across a crankshaft in my parts stash that has the correct part number for a td20 crank (301670). however, it has an unusual cam design and the flywheel key way is clearly different than any other td20 or tn that I have ever seen. a rotor type ignition will definitely not fit and the modern omc ignition uses a cam that slips over the shaft, not ground into it. can someone tell me what I have or what kind of ignition system is needed?
      thank you.
      hotrod
        That crank is probably for a TD-15. To use it, you must also use a maverick spark suppressor for each coil. The TD-15 crank cam flat spot is nearly 1/2 inch wide from its leading edge to its trailing edge. The TD-20 crank has a cam flat spot which is 3/4 inch wide. The magnet rotor for the TD-20 crank is stronger and it is marked by a ‘V’ cast on top. This TD-20 rotor may be used with the TD-15 crank only if suppressors are used and only if they are in good condition. The older magnet rotor without the ‘V’ cannot be used in the TD-20 under any conditions. TD-20 models do not use maverick spark suppressors due to the wider cam flat which prevents erroneous sparks. There were 2 styles of suppressors in the TD-15. The first style suppressor on the TD-15 model had an exposed spark on the mag plate where the coil ground wire went towards ground. The second style had a suppressor that enclosed the grounding spark inside of it.
        #54444
          Interesting about the Maverick Spark Suppressors. As I was
          working on the HD-25, I just read about them in the service
          manual, but the photo wasn’t good enough to see what they looked like.
            I believe Mumbles put this up a few years back. . . 😀
            #54475
            20mercman
              Alright thank you for the input. I might just end up looking for a good td20 crank then, if anybody has one they want to get rid of or want to trade for this one just pm me. its really in great shape just doesn’t match the junk that I have. 😆
              #54484
                Garry, thanks for the photo. Is the "tab" that the spark is arcing to,
                and the capacitor, both part of the suppressor?
