Home Forum Ask A Member Tempo fuel tanks
  • #7285
    burnt-clutch
      Has anyone used these, and are they any good?
      I ran across one of these for free and found that there are rebuild kits for the fuel sender. I’d like to use it for my 54 Fleetwin when I convert it to a single line setup. Thanks.
      -Karl
      #59331
      dave-bernard
        worked fine when I had mine.
        #59333
          Still using one much older than that one in my boat. Gas cap isn’t much to brag about. That’s ok, I don’t think I want it sealed tightly in the hot FL sun.
          #59335
          amuller
            My impression is that these are better than the "other" generic plastic tanks with the threaded-in fuel connectors.
            #59365
              They are 100% guaranteed not to rust. . . 😀
              #59380
                If you want water in your gas, they are fantastic. See how the pick up assembly sits in a little sunken area? Combine that with an almost assuredly bad gasket and you have a rain water FUNNEL. If you are going to use that tank, at the very least, replace that gasket before it bites you in the butt. (If you can even still GET them.) Back when those tanks were popular, I can’t even begin to say how many engine problems we had, because of them. Even if you don’t leave your tank out in the rain, the ethanol gas will draw moisture form the atmosphere, though that failed gasket.
                #59401
                burnt-clutch
                  Allright. A new gasket is at the top of my list. Thanks for the replies all.
                  -Karl
                  #59411
                  rmhxruss
                    Tempo has been out of business for over five years. They made very good products. Age and the new gas will take there toll on old plastic tanks.
                    #59414
                    PugetSoundBoater
                      Tempo is out of biz? so no where to find a gasket. I have one and do leave it outside and it does get condensation .Any leads on gaskets would be great. Suppose i could make one,even RTV may help as a coating in the original gasket. Jim PSB
                      EDIT
                      Robbie Robertson
                      #59420
                        I have found water in those tanks many times as well. Once was diagnosing a no start for an hour, until I determined the tank had water in it!
