Home › Forum › Ask A Member › Testing coils, per1938 Bendix Scintilla procedure
  • #283082
      I’d like to test the Bendix TMD coils per the 1938 shop manual.
      The diagram says to use a “Standard Ford Coil”, and to “short out”
      the secondary.
      Do you suppose they’re talking about a Ford Model T coil, or
      a standard automotive 6v Ford coil per 1938?
      What is the resulting difference if one runs the 6V directly to the Bendix
      coil’s primary, or go thru a Ford coil’s primary first, then to the Bendix
      coil’s primary?
      I have a Model T Ford buzz coil set up with 6v game camera batteries,
      I’ve used to run RBM outboards, that I could use, if that will work.
      I made a new “air gap” tester that will work on my Bendix twin’s two coil system.
      The Bendix coils primary’s are wired in series, and it’s a twin opposed motor,
      hence both plugs fire at once.
      Thoughts? Thanks.
      Coil-Test
      DSCN8710
      DSCN8716
      DSCN8717
      JOSEPH BRINCAT
        I would think that by 1938 it would be a standard Ford 6 V coil, not the model T buzz coil.  Looks like what is going on here is using the Ford coil primary voltage spike to juice the Bendix coil. Normaly one would just use low voltage  ( 6 maybe 12 V) to test a coil, but the voltage from the shorted Ford coil will be considerably higher, like a couple hundred volts… ( I think ?)  We need Jeff R to chime in on this.
        #283091
          I’m wondering if not using a 6 volt car battery and
          substituting the needles will produce the same results?
          Looking forward to hearing what you experienced
          with your testing.
          #283092
          Tom
            While the dates don’t match up, I think they DO mean a Model T Coil.  Using the primary side of a Model T coil would generate the same thing as using a Merc-O-Tronic or a Stevens tester with a vibrator tube.  I’ve done this with a Model T coil and one of the dual output military coils to run opposed twins with no magneto.
            If you put the Bendix primary wires in series with the battery and the top and bottom terminals of a Model T coil, you should be generating a spark in the Bendix secondary.  You would have to put the Bendix high tension wires near each other to see the spark.
            Tom
            #283093
            CHUCK
              Buc…is that from a Bendix Manual for outboard repair?  Is it available as a PDF somewhere?
              #283097
              JOSEPH BRINCAT
                I think Tom is correct. The Model T coil has the “vibrating” points – the make and break function on the primary circuit that’s needed to fire the test coil
                #283098
                  Joe, if one used a regular 6 volt battery, and omitted the
                  extra coil, or Ford buzz box, one would have to operate
                  the points manually to get a spark perhaps????
                  Maybe using the Ford T coil with the vibrating points
                  is why the diagram shows it working with the points
                  isolated??
                    with your testing.
                    Hopefully I don’t report back “Disaster”, as those
                    coils would be few and far between, and not
                    easy to swap out.
                      Tom
                      Your theory sounds very plausible to me.
                      One would think that it would be safe for the Bendix coils
                      if it’s a procedure in the Bendix shop manual.
                      Thanks.
                        Yes, it’s an official Bendix manual for repairmen.
                        I have it in four separate pdf’s, all but one too large of a file
                        to post here.
                        I found it online a few years ago…….. not sure if it’s still “out there”.
