Home Forum Ask A Member The PO-15 is alive!
  • #11275
    david-bartlett
      i fired up the PO today in the yard. Tomorrow we will find a lake.
      In my video you will note I forgot to close the compression release so I had a “One cylinder” motor going.
      Lots of levers and such to deal with. The Cat D-9 of outboards.
      https://youtu.be/JvaEE8_OahU
      #83192
      nj-boatbuilder57
        quote david bartlett:
        Dig it!!
        (I work for a Cat dealer…)
        #83194
        rpsiii
          US Member - 2 Years
          David,
          See it on the Saco??
          Bob S
          #83195
          bill-loveland
            I like it too!
            You may already know this, but the compression release lever also closes the bypass port for the port side cylinder. Easier to crank over and sends the full charge from the crankcase to the starboard cylinder.
            Pretty sharp lads, those Johnson brothers 🙂
            #83198
              Pretty Awesome.
              Not much smoke? What mix are you running?
              #83199
              bobw
                VERY cool! It’s always awesome when you fire up an old motor for the first time.
                #83209
                david-bartlett
                  quote RPSIII:
                  David,
                  Bob S
                  Bob,
                  Sea trials tomorrow. Then Orman’s on Saturday.
                  #83211
                  david-bartlett
                    quote Chris_P:
                    Pretty Awesome.
                    Chris,
                    Believe it or not this was on 8:1. A 50-50 mix of TCW3 and 40wt non detergent. After I run it a while I may cut back a bit. Oil is cheap!
                    #83212
                    david-bartlett
                      quote bill_loveland:
                      I like it too!
                      Bill,
                      I did know that. Those Johnson guys knew a thing or two.
                      #83214
                      bill-loveland
                        OK – I was looking for something else on google image and ran across this – what the heck? That’s not a PO, it’s an SD
