Home Forum Ask A Member Thor Built Sea Kings
  • #9586
      I thought my 2.4 hp Thor built Sea King was a 1937, but after
      discovering my uncle had a 2.4 hp Thor built Sea King as well,
      and in looking up his serial number, came to the conclusion
      that ours our both 1939 models.
      Both our serial numbers start with WK, uncles being
      WK 9XXX, mine
      WK 10XXX.
      They both have the Thor "poppet valve" mixers / carbs. on them.
      The story goes that Kiekahfer bought out the Cedarburg
      Thor building and ending up "re-working" 500 Thor Sea Kings
      that Wards sent back to the factory. I believe I read the
      re-working consisted of replacing the poppet valve carb
      with a conventional "float type" carb.
      Does anyone have a photo of one of these 500 reworked Sea Kings?
      I seen a YouTube video of a purported to be, 1940, 2.8 hp Kiekahfer built Sea King,
      with perhaps a more conventional carb, but it was centered
      in the front of the power head, not off to the side as my 1939,
      therefore, not one of the re-worked Thors, unless the crankcase
      was drastically changed.
      Not able to find out much about Thorwald Hansen and son Royal.
      What did they end up doing after going bankrupt?
      fifty20ne
        Hi Buccaneer,
        I believe the number of returned (rejected) Sea King outboards left in the factory was 384
        Per "Legends Of Mercury" and "Iron Fist"
        I believe this attached picture is of 32 year old Elmer "Carl" Kiekhaefer in the factory getting the reworked Sea Kings ready for shipment back
        to Montgomery Wards in Chicago.
        Walter R Chute (New York Chapter) has written many excellent articles on early Thors for AO magazine!!
          US Member - 2 Years
          Carl,
          Was into magnetics, pigs & livestock, back then, E-clutches related. DO NOT forget how he made better mags 2 😀
          #73645
            Thanks for the photo, information and comments.
            In looking at the carb in the fuzzy photo, I can’t
            tell that it’s any different than the original Thor poppet valve version.
            Will see if I can locate any of Walter R. Chute’s writings.
            Thanks!
            dockbuster1
              I do believe the K Sea Kings had a one piece crankshaft unlike the five piece crank and a dashpot carb like the older ones but with a tickler to unseat the valve which the older ones did not have My 1935 Thor barley runs and starts and the 1939 Sea King is a delite to start and run by comparison
              https://youtu.be/Fiqku68yX3U This is a video of the 1935 thor
              #73653
                Thanks for the video. Thorwald Hansen would be proud to see it still running!
                I looked in the Antique Outboarder archives, and did not see any
                articles on Thor written by Walter R. Chute. Was a good article
                on a twin Thor though.
                quote Callie30R:
                joesnuffy
                  Neat info and history.
                  Joe
                  #73759
                  fifty20ne
                    Attached is a great video showing the Thor VRs Sea King Motor
                    About 16:30 into video watch!
                    https://www.youtube.com/watch?v=IEyE9iD … welXxt_4KT
                    #73770
                      Fifty20One, Thanks for the video link.
                      Looks like my 39 Sea King 2.4 hp was
                      one "tweaked" by Carl as mine has the
                      so named "tickler" on the carb to lift the
                      poppet valve off the seat.
                      The Thor compared in the video must be ealier
                      than the 39 Sea King shown, as there lots of
                      differences in the exhaust to cylinder mounting,
                      water pump, etc.
                      Regarding the Thor, is a "five piece" crankshaft
                      welded together? Are normal crankshafts
                      really a one piece forging? Guess I need to pay
                      more attention!
                      I got the cylinder back on mine today, and now
                      that it actually has piston rings, it has compression!
                      Not sure how much yet as I thought I better let
                      my gasket cement cure a day.
                      Anyone know what the correct 18 mm spark plug for these models?
                      Thanks!
