Home Forum Ask A Member Tiller rope steering controls
  • #256907
    Mallett
      Hello all, I’m try to find parts and info on setting up tiller rope steering controls for my Mercury KF 7. I have the steering wheel and drum installed. Did Mercury sell parts to convert the tiller handle, throttle and shifting lever?
      It looks like the deadman throttle is the way to go, but how does that move the shifter from neutral to forward? Photos or parts numbers would be most helpful.
      thanks
      #256910
      RICK EICHRODT
        US Member - 2 Years
        The KF7 does not have a shifting lower unit.  Once you start the motor, you are off and running.  How the KH7 has a shifting lower unit but I do not think there are any provisions to adapt the shift and throttle.  You might be better off switching to a MK20 or MK25 as there are kits to make it have remote steering, throttle and shift.
        #256916
          Steering Bar maybe?
          #257042
          Mallett
            Thanks for your input. Are they original equipment? Or is this just how people figured it out?
            #257099
              I cant say one way or the other as my knowledge
              only comes from what I have seen others do.
              #257104
              dave-bernard
                bar was factory.
                #258206
                Mallett
                  Okay factory steering bar, thanks. Dose any one know the part number, or have one for sale? Seems like it’s a custom job now. Thanks
                  #258207
                  chuckw
                    US Member - 2 Years
                    Old Mercs has a steering bar for KF, KG7.. Lists at $60.
                    #258221
                    A Hoskins
                      $60 ? Make one, it’s just a piece of flat stock. Bend it to look like the one Tubs pictured and drill some holes in it. In the right place, at the right time, it’s in the scrap bin at a welding or fab shop and you’ll get it for a polite smile.
                      "Fox News" isn't.
                      #258381
                      Mallett
                        Thanks again for your help all, so what do we think the steering bar should be made out of? Bronze brass stainless aluminum? Any idea were to find the original dimensions?  Installing the deadman throttle today and filling  the fabric on forward deck.
