Timing Question
Home › Forum › Ask A Member › Timing Question
- This topic has 32 replies, 10 voices, and was last updated 3 years, 9 months ago by Yellowstone.
May 25, 2020 at 8:45 pm #204043
So, I’m using the timing tool along with an OHM meter and setting brand new OMC points from an OMC Tune Up Kit. I have the “top” part of the tool pointing directly in between the two marks on the mag plate for the top cylinder and can set that. But when I rotated the tool and have the “bottom” part pointing in between the marks, nothing I try gets the meter to stop chirping. I’ve lined the points up, tried loosening and tightening the screws every which way but the points don’t seem to open far enough to break. They’re pretty tight. I can nudge the point with the screwdriver ever so gently and it breaks and the chirping stops. Is there something obvious I’m just over looking. Gonna mess with and readjust some more. Thanks!
May 25, 2020 at 9:32 pm #204046I’m assuming the chirping indicates a complete circuit to ground…Is the meter chirping even when the points are open? Have you cleaned the points? Perhaps the new points are defective. Is the mag plate sloppy? How about trying this backwards….Try setting the points to .022″ (for new points), then use the timing tool to see where the ohm meter indicates they are breaking open…
May 25, 2020 at 10:05 pm #204047Can you manually open the points with a screw driver and get the points to break continuity?
Or is there something physically preventing the points from opening?Prepare to be boarded!
May 25, 2020 at 10:19 pm #204048Thanks. Yes. When the chirping or constant beeping stops then the point has opened. The point never really opens. I wore a headlamp and got my eyeball down there. Ha. I did clean the points. I wiped them. Then I even used a little very fine sand paper and cleaned with clean paper. When you say mag plate sloppy, do you mean its dirty? It was pretty clean but I wiped it down with a little carb cleaner when it was naked. I believe I assembled them right. I can get them to open when the timing tool isn’t lined up. When the “top” on the drive shaft is lined up that point.
May 26, 2020 at 3:15 am #204051Actually, this is the second time I’ve read a similar report recently. As I recall, the last guy also had new OMC points and wound up replacing them with Sierra. I hope I got the story right, it’s kind of foggy here at 3:14 AM (fog’s in my head)
May 26, 2020 at 8:59 am #204053swap the good point set to the other ‘s place and retime …….if OK you can assume the bad set ..is bad
May 26, 2020 at 9:21 am #204054Also just try rotating the crank with the tool and observe the points as it passes the marks. Can you observe the points opening? You should be able to see a gap as it rotates past the marks. I’ve found you need the hold down screw loose but not too loose. I’ve had that behavior and then turned the hold down screw tighter and nudged the base of the points with a screwdriver and gotten it to work where it didn’t before.
May 26, 2020 at 10:11 am #204056By sloppy mag plate, I mean perhaps the bushing is worn allowing the mag plate to move somewhat from side to side, try rocking it back and forth with the points open to see if the gap varies much or if there is noticeable sideways slop…
May 26, 2020 at 1:13 pm #204060Thanks all. I will definitely try some of these tips and tactics later when I can get to it.
May 26, 2020 at 11:11 pm #204122So I tried nearly everything but using the timing tool, I just couldn’t get the bottom point to break using the multimeter. This included trying a few different points. BUT, when I go the basic method without the tool, I can get them both to open easily by lining the “Top” arrow on the cam up with the edge of the point aimed it. That works great. It bugs me about the tool since I know it works great and has for me in the past the couple of times I have used it.
I also noticed tonight one coil’s grounding wire insulation has rubbed away a bit. You can see bare wire some. I wouldn’t have thought it would have rubbed. Thoughts on that? Do you do anything in those instances? Wrap it with anything? These are two new OMC coils I put in a few weeks ago before I decided to go back in and put new points and condensers in. The old coils were cracked to heck.
Gonna try to get the fly wheel back on and see what we have after I give it a second look tomorrow. Thanks for your help!
