Home Forum Ask A Member Tiny oil seal for 1.25 Elgin
  • #6202
    auldscott
      US Member - 2 Years
      I was given a 1.25 Elgin with a loose top main bearing, which ruined the seal. I have a bearing on order.
      I have not been able to find a seal, which is 0.875" OD and 0.125" thick, and runs on a 0.670 " (17 mm) shaft; single lip, rubber covered housing.
      Has anyone solved this problem?
      Thanks,
      auldscott
      #51882
      jim-moffatt
        US Member - 2 Years
        Best source is SKF (Chicago Rawhide)
        here is their lookup page
        http://www2.chicago-rawhide.com/popup_p … 457010.htm
        I couldnt find any seals for shafts .670 . you could try other diameters within .005 or so, they may work.
