Home › Forum › Ask A Member › To Thermostat or no to stat
- This topic has 18 replies, 5 voices, and was last updated 3 years, 5 months ago by Mumbles.
June 5, 2021 at 8:55 pm #239598
Removing the thermostat to have the engine run cooler is only a short term “band aid” , or something to do if you are out on the water and experience an overheat, but need to get back to the dock. The thermostat helps control water flow around the powerhead by imposing a restriction….Parts of the engine could actually run hot running without the thermostat due to uncontrolled water flow and hot spots.
I would pull that cylinder head off and have a closer look, paying attention to mumbles nice photos. I’m sure you cleaned up everything nicely, but perhaps some loose debris ended up in that passage when you started the engine. Don’t reuse the head gasket, replace it again…1 user thanked author for this post.
August 12, 2021 at 11:46 pm #244800Thank you everyone for your suggestions and tips! I really appreciate it, I will check more into the thermostat this fall/winter right now it is running good and not HOT! so I am going to enjoy it for the season and spend time on it this fall to chase down this gremlin.
August 13, 2021 at 1:32 am #244802What convinced you the motor was running hot? Did you check the temperature with an infrared thermometer?
Thermostat motors do run hotter than non thermostat motors so it might have been deceiving if you aren’t used to a T-stat motor. Enjoy your motor!
August 13, 2021 at 7:29 am #244807just curious ? did you check the thermostat for proper operation ? did you reinstall an old one or new one ?
August 13, 2021 at 8:34 am #244808Crosbyman, I put the new Stat in, and the water stopped pumping out the back, and the motor got SUPER HOT! I bout a new stat, but good chance it could have been faulty. Im not sure how you test them.
August 13, 2021 at 8:38 am #244809Mumbles-I need to get an infrared thermometer to really test correctly, But it started smoking, and water wasn’t flowing out the back. let it cool for a couple hours, took stat out ran it, water was flowing fine, and everything ran great! I could have had a bad, New stat. its trial and error now. Thank you
August 13, 2021 at 8:54 am #244812For my clarification… When I have a Stat in. water should be pumping out the back whether or not the Stat is opened or closed.. Correct?? When I had the stat in, water was not peeing out, Took out the stat, water was peeing..
August 13, 2021 at 10:32 am #244815put the thermostat in gradually heated water and pop in a turkey thermometer in the water
you will or won’t… see the mechanical movement open up as temp. reaches about 140-150 F
if you don’t see it open up …it is bad
- This reply was modified 3 years, 5 months ago by crosbyman.
- This reply was modified 3 years, 5 months ago by Mumbles.
August 13, 2021 at 10:51 am #244824For my clarification… When I have a Stat in. water should be pumping out the back whether or not the Stat is opened or closed.. Correct?? When I had the stat in, water was not peeing out, Took out the stat, water was peeing..
That’s right. Water should be coming out of the exhaust relief at all times.
With this motors symptoms, I’d first remove the cover and check the small passage between the cover and the gasket for blockage.
