Nothing wrong with this Gale 25hp carb that I can find, but every time the bowl is drained the float sticks open – tap on the bowl with screwdriver handle and float/needle work just fine. I’m starting to think too much float drop is letting the needle get crooked or some other way hanging up on the seat.
Ahh yes. Those big twins are notorious for flooding, if the float drop is not set correctly. The little tab on the back side of the float will take care of that. Allowing the float to drop for than 1/4" is pointless anyhow, because the needle is closing off a tiny little hole, to begin with.
All I do, is hold the float up, in the closed position and bend the little tab toward the carb body that hold the needle and seat.
