Home Forum Ask A Member Too New Johnson Year ID
  • #256177
      My brother in law drug home a Johnson outboard from a
      landfill / transfer station and donated it to me. It’s missing
      the hood, turns over, but otherwise looks complete.
      It’s apparently a 25 hp, but I can only match the first 5
      model number digits on Marine Engine.
      It’s way newer than anything I’m use to working on, but
      told him I’d check it out some time. If nothing else, trading
      stock, or sell it off for parts.
      Can anyone tell me the year?
      Model #
      J25TE1CT3
      Thanks!
      crosbyman
        Canada Member - 2 Years
        Johnson Evinrude Outboard Model Number Codes (1980-1998 & 1999-Present) (marineengine.com)
        recheck your  letters   CT could be 1983…?
        • This reply was modified 2 years, 10 months ago by crosbyman.
        #256193
          Are you sure it isn’t J25TELCT3 ?  That decodes as a Tiller Electric Long shaft 1983.
          #256194
            Thanks, will recheck the model numbers tomorrow, just came in and
            the garage is all locked up for the day.
              Frank, I bet you’re right, as it is a tiller control, with electric start,
              with start button on the front cowl.
              Will double check tomorrow anyway.
              Just gotta wonder how bad of shape it has to be for someone to
              toss it in the recycle bin!
              Thanks.
              crosbyman
                based on a lot of cases…could be  truly simple….to fix …
                people just don’t know or bother to fix  things or don’t care  …. maybe it just needs a cowl 🙂  and TLC
                #256213
                  eBay listing – Old Outboard Motor. Starting
                  bid of $10.00. I contacted the guy to ask if he
                  new what he had? He said someone had thrown
                  the motor on the aluminum scrap pile at work.
                  Said he brought it home to see if maybe it might
                  bring a few dollars. I sent him some info on the
                  motor and he replied that he had no idea. It
                  ended selling for almost $400.00. Might have
                  brought more if he had re-listed it as a Model
                  6N-HR Champion Hot rod.
                  A "Boat House Repair" is one that done without having tools or the skills to do it properly.
                  #256240
                    I rechecked the Model number of the subject Johnson today.
                    It must have been the paint fumes the first time I tried reading the number.
                    It’s……
                    J25TELCTE
                    Looks like it decodes as…..
                    Johnson, 25 hp, Tiller Electric, 1983, Electric?
                    If I ever get a motor stand freed up, I’ll check it out!
                    DSCN3062
                    DSCN3063
                    • This reply was modified 2 years, 10 months ago by Buccaneer.
                    #256259
                      The last “E” identifies any mid-year engineering changes if there were any changes.  Otherwise, it means nothing.
                      #256262
                        Thanks again Frank.
