Home Forum Ask A Member Top shaft seal leaking of 1967 18hp Evinrude
Viewing 7 posts - 21 through 27 (of 27 total)
  • #268269
      isn’t all this similar to the oil slinger process  whereby any excess oil leaking out the top  is sucked back in  ?
      Yes, very similar indeed, just missing the slinger, unfortunately.
      #268609
      Evinrude 25
        Finally got the top shaft seal out with a homemade tool! The old seal is still in great shape but I change it anyway.
        #268619
          I’m a lifetime member of the
          “Make Your Own Tools Club”
          Very creative in function
          components and appearance!
          #268631
            I think that tool clearly illustrates that “necessity is the mother of invention”.   Nice piece of work.
            #268645
            Monte NZ
              International Member
              Brilliant effort……well done!
              #268685
                Well, you certainly put some engineering and thought into that seal puller.  Please don’t forget to check that intake passage to make sure it is clear as well.
                #268695
                  For what it’s worth, I had a 58 J. 18hp with a leaking top seal. I used s tiny drill bit & vacuum hose to put a hole in the metsl of the seal 180 degrees out. Put a drywall screw in a few threads & had my pulling device. Cleaned every mating surface. including the seal as it may have mold release or oil, then used marine sealer & Correct sized scocket to tap into seated. I was lucky the side play in the top bearing/bushing was still within specs.  good luck
