Home › Forum › Ask A Member › Transom clamp
- This topic has 12 replies, 7 voices, and was last updated 3 years, 7 months ago by
JOSEPH BRINCAT.
February 9, 2023 at 1:38 pm #272558
Is there a trick to removing these screws? It gets tight at the end of the threads. I don’t want to force it.
This topic was modified 3 years, 7 months ago by
Mumbles.
February 9, 2023 at 2:03 pm #272562The threads tend to get distorted at the end where they meet the cup so using a thread file with the correct pitch to clean them up should work.
This reply was modified 3 years, 7 months ago by
Mumbles.
February 9, 2023 at 2:50 pm #272565Thanks mumbles. I have no thread files. Il have to go looking for one. Correct pitch I’m not sure about.
February 9, 2023 at 3:13 pm #272566If you have a die the correct size, you can screw the clamp bolt in and rethread the tip of the bolt. I have also had luck just unscrewing the clamp bolt into the threads of the clamp until it is tight, then screw it back in until it’s loose. Then repeat the process over and over. The threads of the clamp bracket will gradually reshape the bolt threads as it works it’s way through the bracket. Use plenty of lubricant and just don’t apply more force than you would if you were tightening the motor onto the transom.
February 9, 2023 at 4:52 pm #272567to reinstall the cup drill the shaft and tap it for a small flat headed bolt. Apply blue thread lock
the end of the handle is broken and sharp…. just mix some JB weld epoxy apply and shape it like a new handle…. finish with sanding and some paint
JACQUES.
February 9, 2023 at 8:18 pm #272578The thread size is 5/8 X 11 and right now Princess Auto has thread files on for less than half price.
https://www.princessauto.com/en/thread-restorer/category/360-005-100-055
February 9, 2023 at 10:00 pm #272580With care you can also use one of the shaped files in a cheapie pack of imported needle files to file the sides of the end threads. Then run the thread in/out with lots of lube as described above.
February 10, 2023 at 5:37 am #272583I think the thread file is the way to go, but it’s a little tedious. I have tried both a female thread chaser and a real die, ($$$$) to try to speed up the process. Both of them had a strong tendency to want to cross-thread, rather than find their way on to the existing, damaged thread. One thing I have been doing lately, with tight or frozen clamp screws, is to drill out the retaining pin for the handle, so I can use an adjustable wrench on the screw part. After the screw part is free, I have been putting the handle back on with a staked piece of 3/16″ aluminum rod stock, which is basically what OMC did in the first place.
February 10, 2023 at 6:35 am #272584You didn’t mention what model motor this is off. The smaller motors used 1/2 x 13 threads on the clamp screws.
February 10, 2023 at 7:43 am #272585Ha ! the big question again….
Would heat shrink the inside diameter of the bracket threads….. allowing the shaft threads to pass more freely or….
would heat expand the inside diameter of the bracket threads…. preventing the threads from passing more freely
based on the ball in the hole experiment below …. heating the bracket fast enough BEFORE the shaft also heats up and expands
should allow the shaft to rotate more freely. Freeze spraying the shaft while heating the bracket would likely help.
what about just freeze spraying the shaft ??
would it shrink the diameter of the shaft threads allowing the shaft threads to pass more freely ? maybe
see text below…. borrowed on Internet….and a test I did in high school many moons ago
Thermal Expansion – Ball And Hole
Purpose
To illustrate thermal expansion in a paradoxical way.
Equipment
Metal ball and hole on handles, burner with matches.
Suggestions
Before performing the experiment students are asked:
When the plate is heated, will the hole get bigger, smaller, or stay the same size? Many people misinterpret the idea of expansion to believe that the plate will expand inward, making the hole smaller.
Images
Description
At room temperature the ball will not fit through the hole in the metal plate. When the plate is heated by a burner for about 30 seconds, the ball easily fits through the hole.
