Home › Forum › Ask A Member › Two stroke fuel mix
  • #294409
    Hi,
    Just restricted a script Atwater outboard from 1947
    Still have alittle more work but was wondering what would be a good oil and gas mix for the 3.5/6 engine
    Pn
    #294424
    Sam M.
      Minimum 16/1.  When mixing 2-stroke fuel, keep in mind a little more oil is safer than a little less.  Go for TC-W3 oil as that’s a water cooled motor.  Also, ethanol-free gasoline is safer for old motors than regular modern gas.
      #294450
      Thanxs…been some time so nice I seen this 3.5/6 hp run
      Cleaned up ok..working on the rust in the gas tank with vinegar…hope it works…
      #294453
      Sam M.
        Vinegar should get rid of the rust.  It’s a good idea to give the tank a thorough rinse afterwards to get all the acid (and rust particles) out.  Then blow the rinsing water out with an air compressor before filling the tank with mixed fuel,  or  shake a little oil inside the tank,  so it won’t rust again!
