Home › Forum › Ask A Member › Uh oh. Removed flywheel magnet
- This topic has 4 replies, 5 voices, and was last updated 2 years, 1 month ago by
JOSEPH BRINCAT.
October 26, 2024 at 12:21 am #291751
I’ve done the unthinkable and the flywheel magnet came off this 1989 Chrysler 125 block … I put it on the workbench removed the magnet started sanding it and getting it ready to reattach the epoxy.. . Suddenly I realized that I had twisted and turned the magnet so many times I didn’t realize which way was up or down.
And I done so much sanding that there was no marks to line up other than with a magnet starts and stops line.
So I’m not even sure how to phrase this question …but.. does it matter ifthe flywheel magnet is north-south or south-north?
At this point I’m too worried that I might get it wrong… I’ll have to get another flywheel and a handheld test magnet with a north-south marked on it and identify?
October 26, 2024 at 8:13 am #291754
I’m self taught. Most everything I know comes from experience. Keeping that in mind – I mostly mess with earlier motors. I also have a magnet charger. Some flywheel’s have the north pole marked. I would use a compass the check the ones that aren’t. (North pole of compass points to South pole of flywheel magnet.) Most often the North pole of the flywheel magnet passes over the coil first. I can change the polarity on the early magnets with the magnet charger. I could never see that it had any effect on the spark produced. Does it change which way the spark travels at the electrode like reversing the polarity in a battery ignition? Don’t know. If you’re also generating current to charge a battery it may matter. What is critical is the point where the polarity of the magnet changes as it passes over the coil so the magnet needs to be in the correct location in the flywheel. You might also experience some clearance issues between the magnet and the coils when you get it back together.
October 26, 2024 at 8:32 am #291755your picture actually shows a band of small square magnets (See marks on the band) which may help solve the problem .
In the ETEC engines the magnets are individually glued and sometimes break off !! (cheap glue I guess) Find N/S alignment becomes critical for reassembly
In your case the whole ring seems made up of a band of alternating series of magnets.
Generating an AC signal from magnets simply comes from the changing (alternating) magnetic fields as the FW rotates.
That said your band of magnets should do the job in either position because the pick-up coil (s) would still output an AC signal .
just my opinion till more info is available. !
October 26, 2024 at 10:58 am #291756I would suggest looking on ebay and elsewhere on the internet for pictures of your exact flywheel. If you have the part number hopefully someone will have one for sale. Maybe their pictures would help?
Don’t forget to check both current and “Sold” listings. Some people post really good pictures.
You could also contact the seller and ask for more specific pictures or measurements.
October 26, 2024 at 2:42 pm #291759I think that what crosbyman said makes sense. Should work either way.
