Home Forum Ask A Member Unable to stop 1924 Johnson BNL 2hp running
  • #291133
    Monte NZ
      International Member
      I feel stupid requesting help with this problem, but I cannot work out why I can’t stop the motor running!
      Yesterday I gave it it’s first run and am very pleased to report that it started on the second pull, which I thought was great, as it possibly hasn’t run for 80 years or so!
      However, when I went to stop it by pressing the stop button, the motor just carried on running until I chocked it.
      Attached are shots of the mag. The only thing I have done is to clean the points and replaced the condenser.
      I thought the photos may help you see the problem……..I thought going over the mag with my meter would find the problem, but no luck!
      https://photos.app.goo.gl/1TWyTMeaadwnTAUq6
      Thanks in advance as always for any help!
      Monte NZ
      #291134
        Diagnosis with an meter is needed to check continuity
        in the kill circuit. Open circuit, or dirty contacts
        on the kill switch.
        GARY
          Assuming you’re holding kill button down long enough,all that’s left is to use meter to check that points are actually grounded when button is pushed down.Check for corrosion where brass tab is screwed to under side of mag plate handle and for continuity of kill switch wire running to points.
          #291141
          JOSEPH BRINCAT
            Monte, Good job on getting her running.  I did get a chuckle about not being able to stop it. Normally we see lots of “no start” questions , not many “no stop” questions.
            #291164
            Monte NZ
              Hi Buc, Stanley and joecb, thanks very much for your suggestions
              Good news! The stop button now works!
              I tested it by removing the plugs and spinning the motor in the dark and pressing the stop button on and off.
              The reason I hadn’t checked more thoroughly, was the motor is a fresh water one with no sign of corrosion, but it just shows you how it pays to be a bit more thorough…….lesson learnt!!Below is the link photos of the motor (power head) before and after…….the gearbox (which is in excellent condition )  is the next job.
              Below is the link to several photos of the work process on the motor.https://photos.app.goo.gl/q1ZktYctPT4xzD5w7lease excuse the picture of us in Queen Street Auckland!
              Thanks very much once again for your help.
              Monte NZ
              #291168
                Looks like a nice little motor. Glad you got it fixed.
                  Looking at your as found picture, you started with a really nice example. I didn’t run the twins I had very much but I have a single I have run a bunch. Great reliable, good running motors. I’m sure you will enjoy running yours. Tubs
