Home Forum Ask A Member Unknown prop engine
  • #10002
    dieselcowboy
      Hey guys I just bought this small prop engine. Don’t see any markings on it. Google searches leave me empty handed. Can you guys shed any light on this subject?
      bill-loveland
        That’s a new one on me – the powerhead pointing down
        #76545
        Tom
          Can you post photos of the carburetor / intake and the side with the cylinder(s)? If I had to guess, it looks like a homemade motor, using a Mercury powerhead. But the tower castings seem to match up well with the block and the intake casting is quite unique.
          Single cylinder? Air cooled?
          Tom
          #76548
          dieselcowboy
            Sure can guys. It will be tonight when I get home. Ill try to get several different angles.
            It is 2 cycle – single cyl with tillitson carb. Adjustable timing. Timing plate has a handle on it.
            #76554
              Hopefully just an optical illusion, but one side of the
              prop looks to be a foot longer than the other!
              What ever it is, it belongs in "Rippley’s Museum for the Strange and Unique"
                Looks like a Jacobson Lawn Mower gas tank.
                #76591
                dieselcowboy
                  Under all the silver is like an olive dab green color over the complete unit.
                  dave-bernard
                    that olive drab is zinc chromate primer.
                    #76599
                    dieselcowboy
                      That primer must be pretty heavy duty. Common on older engines?
                      #76605
                      mike-stroz
                        Looks like a Lawn Boy engine to me, and I believe the gas tank is from a Jacobsen mower.
