Home › Forum › Ask A Member › Using Anaerobic sealer
- This topic has 5 replies, 4 voices, and was last updated 4 years, 7 months ago by
fleetwin.
May 1, 2021 at 5:19 pm #237495
Using it for first time on a crankcase.When I use regular sealer I put a few spots to hold the spaghetti seal in place and a bit at the ends where it hits the bearings.How do I accomplish this with an anaerobic sealer or is it even necessary?
May 1, 2021 at 9:54 pm #237506Do not use the OMC Gelseal or any anaerobic sealer with a block that uses the spaghetti seal.
May 2, 2021 at 6:37 am #237522Why?
May 2, 2021 at 11:00 am #237538Spaghetti seal crankcase flanges require the type M/847 sealer to be used. In reality, you shouldn’t really need any sealer on spaghetti seal flanges, the spaghetti seal does all the sealing. The type M is used to help glue the spaghetti seal in place so it won’t fall out of the grooves during crankcase assembly. You surely don’t need to use much of the sealer, just enough to glue it in place securely. The anerobic sealer will not set up with air present, so it will be useless in terms of gluing the spaghetti seals in place.
Sealing crankcases properly can not be over emphasized, it is often seen as a minor chore with little significance. Spaghetti seal and type M/847 are used together…Anerobic sealers are only to be used on flat crankcase flanges with no grooves/spaghetti seal.
The benefit of the type M/847 is that it sets up quickly and strong. This benefit is also one of its detriments, because parts have to be assembled quickly, before the sealer hardens, or the crankcase halves will not mate and seal properly.
The anerobic sealers are nice to use because they don’t set up quickly, until the crankcase halves are reassembled and the air is removed. The downside of the anerobic sealers is the prep, which is critical…Improper surface prep will result in poor sealer performance, aka crankcase leaks. Something as innocent as greasy fingers while applying the anerobic sealer might be all it takes to keep the sealer from setting up properly.May 2, 2021 at 12:28 pm #237540Respectfully, I have used anaerobic sealer on spaghetti grooved motors with success. OMC’s Gel Seal was the go to sealer years ago while building three cylinder 70 horse motors with grooved cases. The machined surfaces of the cases do contact each other so the sealer will work as long as the surfaces are prepared properly. That means clean and bare aluminum as the copper in the aluminum used is what helps kick off the curing process. Copper based primer is used to speed up the curing when the motor is going to be used shortly after it’s together.
The 3M sealer has its place but I find it hard to use and it seems to get everywhere and makes a mess. Something like Anti-Seize or Sikaflex does.
May 2, 2021 at 7:13 pm #237552Totally agree that the type M/847 is messy, wish they made it in smaller tubes with smaller tips.
