Home Forum Ask A Member v bottom boat
  • #160891
    Tinman
      hello everyone. Looking to buy my first v bottom boat. always had flat bottom jons. Looking at one that is 15 long was told it was 61 inches across the beam. Im looking for something stable so i can stand and something that can at least handle up to a 20 hp motor….anyhting i need to look for? what is a good size to for stability? also need something fairly lightwieght so i can handle it by myself. thanks.
      #160899
      Tinman
        The boat is a richline brand.
        #160906
        auldscott
          The thing that strikes me is “…lightweight so I can handle it by myself.” If you plan to pick it up and carry it yourself, or load/unload it using a truck, the 15 footer with a 61 inch beam is probably going to weigh about 225 lbs and be awkward to handle.
          As to handling a 20 hp, most boats that size will, but check the capacity plate.
          The 61 inch beam is a little narrow, but it’s nothing like a 48 inch beam (or thereabouts) jon boat as to stability.
          I have a 14 foot v-bottom with a 65 inch beam. It weighs 250 lb and is rated for up to 30 hp. I can stand up in it with some confidence, but it’s still a small boat.
          #160911
          Tinman
            By lightweight I mean move around on a trailer fairly easy by myself. Not looking to pick it up. The reason for looking at a v bottom was a few lakes I fish the flat bottom is pretty rough when the water gets choppy.
            #160915
            jcrigan
              You will probably need a long shaft outboard as the transom will be around 20″.
              #160931
              Tinman
                It’s a 15″ transom.
                #160939
                crosbyman
                  15″ ?? better not have strong back winds
                  #160977
                  vintin
                    I’ve got a 1958 Alumacraft Deep C that I would sell for $575.
                    Alumacraft-Deep-C
                    #160989
                    Tinman
                      Where are you located?
                      #161000
                      vintin
                        Auburn GA 30011
