Home Forum Ask A Member V3100 Clinton Outboard
  • #255430
    seakaye12
      I’m curious;  are there very many of these around?  Clinton V3100-2000
      Clinton-Small-2
      Clinton-Large
      • This topic was modified 2 years, 11 months ago by seakaye12.
      #255435
        I’ve sure never seen one.  Looks too good to be a back yard hack.  Prototype???
        #255437
          It’s pretty mean looking with that exhaust! None like it in my garage.
          need2fish
            Are there any other numbers ? — I think V3100-2000 is the engine (powerhead) model #. If it’s a production outboard, you may be able to find the it’s model # somewhere else on the unit.
            #255452
            seakaye12
              Well….there is least ONE other one.
              https://www.ebay.com/itm/294263578272?hash=item448379dea0:g:AWQAAOSw5Qxg5gcA
              Reading online on a Clinton forum there is mention of the motor being sort of a custom build by a company in Seattle???
              #255647
              jcrigan
                It’s a Seapacer outboard. With a 2.5hp, 4 stroke, Clinton engine. The V in the model number indicates it is vertical shaft. The lower parts are the same as those other 2 stroke Clintons. The one i have doesn’t have a water pump to cool the motor leg.
                #255649
                  Obviously doesn’t have to cool the motor leg, since it has that goofy looking above-water exhaust/muffler.
                  #255661
                  seakaye12
                    Seapacer.  jcrigan;  have you seen mention of it in any Clinton literature or elsewhere?
                    Here is what someone on a Clinton Forum said:
                    This model outboard, VS-3100 was the brain child of John Roby, President of Roby & Sons, Inc located in Seattle, Washington. John was the only independent distributor for Clinton Engines in the South Pacific Area. Roby contracted out the manufactured the driveshaft housing, gear case and did all the assembly work on the unit in Washington. In application a round hole was cut in the bottom of a small/medium size boat and the unit was secured to the boat via the transom plate. The unit had a handle and was capable of swiveling to accomidate steerage. John had a unique relationship with Don Thomas and this marketing product was processed for manufacture by the Manufacturing Engineering Section at Clinton.I rather doubt Roby is still in business and I would think any service literature would be a rare find
                    That post was found here:  https://www.tapatalk.com/groups/clintongasfr/v3100-outboard-t375.html
                    • This reply was modified 2 years, 11 months ago by seakaye12.
                    #255663
                    seakaye12
                      Now that I have a name  (Thanks jcrigan) I see reference to it.  Peter Hunn of course makes mention of the Sea Pacer.  And;  here’s an ad from a 1962 Boating Mag:
                      Seapacer-Ad-copy
                      #255705
                      jcrigan
                        Makes sense now that it was made here in the Pacific nw. I haven’t seen them anywhere else.
