Home › Forum › Ask A Member › Vintage Single OMC Line Fuel Tank
- This topic has 18 replies, 12 voices, and was last updated 7 years ago by
vintin.
April 20, 2018 at 2:11 am #74358
I have 3 tanks….1 I bought last night on CL for $30 bucks, and it’s like new, another that I bought last year that’s in "OK" shape which I used last summer, and a 3rd that’s a rusty specimen. I’ve never really looked at any of the connections very closely at all & now come to realize that I don’t even understand how they really work.
3 questions come to mind:
– The 2 pins: one is clearly a shut-off valve for the gas pickup tube, but what does the other one do? I press it and can neither blow nor suck air through the pickup tube. If it does something, I can’t figure out what.
– The hose connector: when I snap it on to the tank, it doesn’t seem to sit face-flush to the tank connector on any of my tanks; the connector is being "pushed away" by the pin that activates the valve. Is that normal?
– Lastly, When I squeeze the bulb on the hose, am I simply sucking from the tank & pushing to the engine, or is there more to it than that?
April 20, 2018 at 5:47 am #74361The expanding bulb pulls the gas from the tank, squeezing it pushes it to the motor . . . 😆
April 20, 2018 at 8:19 pm #74389Thanks for that.
I’m still wondering what the "other" pin does. Anyone know?
April 20, 2018 at 8:56 pm #74393As I noted in previous post, one pin lets fuel out, the other lets air in.
April 20, 2018 at 10:09 pm #74394If the leak is coming from that tiny o-ring in the valve Chinewalker is referring to then this will help.
http://www.oddjobmotors.com/tt4_singlelinetanks.htmApril 20, 2018 at 10:18 pm #74397I sure miss Art’s input on this site. He always had something good and beneficial for everyone to say.
April 21, 2018 at 9:53 pm #74457The wee o-ring behind the wee brass washer surrounding the fuel pin is the usual culprit causing leakage between the connector and tank housing. You need to be aware that there are two sizes of "wee", and order the correct one. Older ones are tiny and thin. Then they went to thicker ones.
April 24, 2018 at 2:02 pm #74647I have occasionally used the Attwood connectors, and have not had a bad one yet, but based on others’s experience here, I avoid them unless I need one fast because I can get them at Walmart.
If you do go with the Attwood, read the package carefully because there is a metric one that fits Yamaha and some later model Mercurys, and it looks like the OMC connector but has slightly different dimensions and will not work on OMC.
DaveApril 24, 2018 at 3:37 pm #74656I’ve also used the Attwood connectors and have had good luck.
I will not be buying any more though.
