Home › Forum › Ask A Member › Vintage transom clamp pad replacement
  • #287672
    T….in Wisconsin
      I have a few “A’s” that need the transom screw pad replaced, how are they best removed.
      T.. in Wisconsin
      #287754
      JOSEPH BRINCAT
        insert a thick “U” shaped spacer between the back of the pad and the transom bracket and unscrew the clamp screw… the pad will pop off. A handy “U” spacer is the opened jaws of a large Cresent wrench.
        Joe
        PS, why do the pads need to be replaced? look OK in the pix
        #287757
        T….in Wisconsin
          Hi Joe,
          Clamps in picture are from a parts motor.
          One clamp on restore motor has a broken thumb screw.
          I’m also searching for piston rings if you have a lead on where to purchace.
          I’ll give “Marine Engine” a call on Monday.
          Thanks for replying.
          T…
          #287759
          T….in Wisconsin
            Better picture….maybe?
            #287768
            GARY
              The Penns currently have those rings listed on EBay under antique Johnson outboard
              #287770
              T….in Wisconsin
                Thanks, I’ll check into that.
                #287772
                T….in Wisconsin
                  I did not find the rings on e-bay offered from Penn. OEM Ring# 5-194
                  I only found a set of butt-end rings from another seller, mixer…x
                  #287775
                    Try Ed Elliott.  He might have the rings – eddelliott@cox.net
                    Tubs.
                    #287776
                    T….in Wisconsin
                      Thanks Tubs,
                      I sent Ed and e-mail.
                      T..
                      #287788
                      GARY
                        That’s Doug Penns EBay name
