Want to switch to Philips head –gears case screws RDE-17 1955 Johnson 25 hp
Home › Forum › Ask A Member › Want to switch to Philips head –gears case screws RDE-17 1955 Johnson 25 hp
This topic contains 15 replies, has 6 voices, and was last updated by lloyd 1 week, 6 days ago.
February 8, 2019 at 8:12 am #166314
Well-I messed up the slotted screws(33-76) that fasten the clam shell gear case together. It was mentioned before that OMC later went to Philips head. Hopefully these Philips head are the same size (head and length) as my slotted screws.
The slotted screw I have are ¼-20
Does anyone know the part number of said Philips head screw so I can put an ad in the classifieds??????Attachments:
You must be logged in to access attached files.
February 8, 2019 at 8:18 am #16631733-76 is the original part number, but I don’t get any “hits” searching
for them, even if I add a couple of zero’s as such……. 003376The 1957 35 hp shows…… 0330562 , available on MarineEngine.com,
but they don’t appear to be phillip head either.Prepare to be boarded!
February 8, 2019 at 8:28 am #16632133-76 (slotted) is what I have
I am looking for Philips head part number
Maybe the question should be –
What year did OMC start using Philips head on their calm shell gear cases?February 8, 2019 at 8:51 am #166325Why not got to the hardware store and buy what you need. in SS.
February 8, 2019 at 9:11 am #166330OK, my 1955 catalog says your motor takes 304070, which ME supersedes to 0330562 hex head. So if we can believe what it says, the 0330562 should work in your motor. It obviously has a small hex, likely 5/16″ (???).
The picture you posted is what ME shows for 0330562.
This reply was modified 1 week, 6 days ago by
frankr.
frankr.
February 8, 2019 at 9:52 am #166335The screw needs to have the built in washer
February 8, 2019 at 10:01 am #166340Frank I sure would like to see your library
I don’t know how you translated 33-76 to 304070/ 0330562
But I believe you
Now to find nine of them cheaper than 4.75 a piece
Maybe Ed or Ken will have some -
You must be logged in to reply to this topic.
