I just spent an hour searching for an old post I saw a while back that described how to remove a bearing housing, the bottom part of the water pump that holds a seal.
It involved using two screws or bolts spaced to fit the holes in the housing that the water pump screws pass through.
I’ve used the technique before and it worked great, but now I can’t find the post that described lt.
Any suggestions?
It’s for a ’56 5 hp Sea King, GG8960A.
Thanks,
Geer
