Home › Forum › Ask A Member › ’57 Johnson 10hp Water Pump Leaking
  • #289588
      I am rebuilding a 1957 Johnson QD18 10Hp. I got the water pump kit for that motor, and after putting it together the water pump does indeed pump water. My issue is that the top of the pump housing leaks around the driveshaft a fair amount. There is no “seal” in the pump housing top for the driveshaft, no o-ring. There is no seal or o-ring that goes on the outside of the housing either. The only o-ring goes at the top of the driveshaft where it mates with the powerhead.
      So, is this leakage normal as long as there is water flowing from the water tube? Is it a sign that the pump housing is too worn?
      What do you think? Let me have your feedback,
      Thanks,
      '57 Johnson QD18 10hp
      '53 Sea King 3hp
      #289589
        if you installed the correct pump housing I would not worry about it unless engine cooling is affected.
        #289607
        aquasonic
          At the top of the impeller housing there is no seal where the driveshaft passes through so some water will make its way through. I have had housings that were saltwater corroded at the driveshaft opening that had to be scrapped.
          A good seal at the water tube grommet, clear passageways, a good housing and impeller, and you should have good water flow. Maybe run the motor and observe the spent cooling water. The OMC 10 hp should pump a lot of water.
          Improvise-Adapt-Overcome
          #289610
            Am wondering how you have determined that water is leaking from the top of the impeller housing while pumping.   Some of this “leakage” is normal and expected.  Needless to say, excessive leakage from this area will diminish pump output to the powerhead.  Excessive leakage is usually caused by grooving/pitting on the top surface of the impeller housing.  Worn rubber on top of the impeller, poor impeller fit, or a damaged/distorted SS impeller plate will cause excessive leakage in this area as well.   This is an area where it usually best to use OEM parts.
            Like you say, there is no conventional seal on top of the water pump on this engine.  The “seal” is the fit between the top of the impeller and the aluminum impeller housing.  That being said, some leakage in this area is normal and expected.
            #289616
              Actually, there is another part to this subject.  A “seal” is needed to keep air (exhaust) from entering the pump.  Notice the well surrounding the drive shaft hole and the small hole drilled at an angle into the well.  That bleed hole keeps the well filled with water, providing a water “seal” to keep air out.
              Water-pump-housing-bleed-hole
              #289618
                see bulletin on the subject
                #289660
                JOSEPH BRINCAT
                  And that is why we need ( and appreciate) Frank around here… Thanks Frank
                  #289665
                  labrador-guy
                    10-4 on that mister B!
                    dale
                    #289669
                      I thought Franks pictorial was a good one for my files, but
                      a little hard to read, so I redone it for my own use, but
                      thought I’d share it. Hope that’s okay Frank, and if I got
                      anything wrong, please let me know.
                      Water-pump-housing-bleed-hole-1
                      #289701
                        Great point indeed Frank!
