Home Forum Ask A Member ’57 Johnson 10hp Water Pump Leaking
  • #289705
      buccaneer, I replaced my picture in my file with your new and improved version.  Great minds run in small circles.
      #289806
        Thanks Guys! I had the inlet screen still taped over from painting, and the impeller plate needed a better seal job. I corrected both and the water pump pumps very nicely. The water fountains out of the water tube.  I was testing the water pump in a barrel using a drill to turn my drive shaft. I wanted to get it right before installing it on the exhaust stack. Thanks for all the help.
        '57 Johnson QD18 10hp
        '53 Sea King 3hp
        #289833
        aquasonic
          Testing the pump in a barrel with a drill to turn the driveshaft is a great check to verify a good supply of water to the powerhead. Good luck with your restoration!
