Home Forum Ask A Member Water Witch
Viewing 10 posts - 51 through 60 (of 84 total)
  • #213640
      • This reply was modified 4 years, 1 month ago by Tubs.
      #213715
      kirkp
        Runpet, sent you a pm.
        Kirk
        #213752
          I don’t have a twin cylinder Waterwitch, but did try a coil conversion to replace the Eisemann
          coil on a twin cylinder Neptune, first with a B&S coil, then a JD Pony Motor coil, neither one
          which ended up running the motor. Supposedly some people have had success with these though.
            #214138
            Ralph Simmons
              when you may this attempt did work?
              Q. on a coil with a single spark plug coil
              what is the amount of volts in this coil generating?
              compared to a dual spark plug coil? are they the same ?
              #214421
                #216435
                runpet
                  Here is my restored 1936 Waterwitch. Just finished it.
                  #216452
                    Its not done. Your missing the vent. PM
                    me you address and I’ll send you one.
                    #216457
                      US Member - 2 Years
                      Runpet,
                      If interested in red plug wires go to a neon shop & ask for “GTO” red wire. GTO means Gas Tube Only. It is rated at 15,000 volts for neon conductors & looks like regular 7mm plug wire. Should cost a buck a foot.
                      #216487
                      Ralph Simmons
                        i have a water witch it does run will a squirt of fluid
                        I want to get another condenser for it
                        looking for a newer condenser that would work ,
                        i not sure of what type to use or micro ferrets
                        I used a coil from one of my Elgins
