Home Forum Ask A Member Water Witch
Viewing 4 posts - 81 through 84 (of 84 total)
  • #217226
    runpet
      Mas, your vent nob is on the way. Thanks to Tubs.
      Dick
      #217405
      Ralph Simmons
        working with my w.w.
        does run with squirt starting fluid in it
        But I have a terrible rattle coming area of
        main crank underneath stator plate
        Lifting up on crankshaft I have up-down play
        i would say there is about 1/8in movement up/down
        movement maybe worn bearings inside ?
        under cam follower there is two seals and wave washer
        when installing flywheel are there any spring / other than a wave washer
        that goes between top shaft and bottom of flywheel??
        asking knowing there probably no manuals ?
        • This reply was modified 5 years, 12 months ago by Ralph Simmons.
        #217462
          #217666
          Ralph Simmons
            i will check on that
            If there is anything that be done for slop in any of these conditions?
