Home › Forum › Ask A Member › Weak spark on 1973 20 Hp Johnson
- This topic has 72 replies, 13 voices, and was last updated 5 years, 9 months ago by
Don.
October 9, 2020 at 7:53 am #218195
I had completely torn the whole block apart and honed the cylinders with the honing tool. I clean up mating surface with emery cloth!
October 9, 2020 at 11:05 pm #218231OK, well let us know how it runs with the other carb…
October 31, 2020 at 12:48 pm #219774I Just bought a new gasket. I removed the head and wanted to change it but I when I spined the flywheel and heard this sound. Is it normal? Please review the video.
https://youtu.be/-L92BvQHY6wOctober 31, 2020 at 12:57 pm #219777Put it in neutral and remove your manual pull starter assembly. Look for anything rubbing around the flywheel as you are turning it.
You can do a much better job of torquing the cylinder head if you remove the power head from the base.
October 31, 2020 at 1:06 pm #219782It’s not your dry impeller making that noise, is it?
October 31, 2020 at 1:36 pm #219787It’s not your dry impeller making that noise, is it?
That’s what I was thinking….Sounds like the impeller, but seems to be a pretty darn tight fit….Pull the gearcase off and spin it again….
October 31, 2020 at 1:43 pm #219788PM me with your email address, I will send you an electronic pdf service manual for a 1973 Johnson 25hp outboard to help you along.
Cajuncook1
October 31, 2020 at 9:59 pm #219818Yes, as per your suggestion, I put my ear closer to the lower unit and heard the sound down there. It is a dry impeller!
So today I ground the head on 1000 grid sand paper and install the new gasket. I torque down first step at 6 ft lb and second step at 10 ft.lb. Then I stop for now. I remember Fleetwin mentions the torque value 120 in lb but I look up other Forrum, the head torque value to 210-240 in lb. please correct me the right torque value. I cculd not use the torque gun to torque two bottom bolts so I did it with the wrench at the best I could closer to 120 in. lb. I don’t want to remove the whole block since I have to order a new base gasket.November 1, 2020 at 12:33 am #21982396 to 120 in-lb. is correct.
"Every time you remove a broken or seized bolt an angel gets his wings."November 1, 2020 at 8:03 am #219826Just wondering what got you to pull the head back off…. Kinda thought you were gonna try a different carb, did I miss something?
