Home › Forum › Ask A Member › Weak Spark
  • #288841
    Fastwin18
      Are the plugs dry or wet after a few starting attempts?
      #288842
      Yes , Fleetwin ,  I can see some spark but when i inject a lubricated starting fluid or fuel into the spark plug hole i get No pop . I know this is crazy. Im gona clean the points and get the J6C plugs and try again.  Im wondering if its something with the flywheel but i have set the coils as correctly as i can.     Thanks !
      #288843
      Dry , but i wet them with fuel when using a lubed starter fluid.
      #288844
        Too much fuel, or starting fluid wont ignite. Squirt one into the cylinders, pull the motor over half a dozen times, then put the plugs back in and try to start it.
        #288859
        Ok Guys  , I finally got her to run , last thing in did was to inspect and clean the reed valves.  Bad !
        Needless to say i should have done this in the first place , but im learning.
        Thank you all for your help I appreciate it !  D
        #288903
        Thanks
