Home Forum Ask A Member Welsh plug
  • #1041
    dmbono
      I have disassembled an early cast tank Johnson waterbug. I would like to clean out the cylinder water jackets. The welsh plugs are pennies. I will make new plugs- question is what material did Johnson use? Steel or brass come to mind
      #12890
        I’m sure the early Johnson welch plugs were made of steel or iron as I’ve had several which were rusted through. I make replacements out of aluminum and epoxy them in place.
        #12917
        melugin
          Although not original, a very old penny will add authenticity. One of my motors has a 1916 penny replacing the Welch plug. . A small peen dent is where the mint mark could have been. A 1916 D penny would be worth more than the motor.
          #13010
            I have seen several Antique Johnsons with a penny from there year of manufacture in the welsh plug socket. I think they are really cool … 😀
            #13150
            dmbono
              Thank you all for your replies. I popped the pennies- they were stuck good! I’m soaking the jackets with lime and rust juice before capping the plugs again.
