Home Forum Ask A Member What size battery for electric start Fastwin?
  • #1066
      What size ("group") battery do you use (or suggest) for an electric start Fastwin.
      I’m working on wiring one up, and need to figure out what kind of battery to get, and what kind of terminals.
      Thanks!
      Phil
      Yankee Chapter
      #13065
        What kind of ends do you have on your cables? "Group" refers to physical size. The commonest red battery boxes are sized to fit a Group 24 battery. But there are also ones to fit a Group 27. I’ll catch heck for saying this, but I go to Wally mart and pick out the smallest (lightest) one on the shelf–to heck with the "Group". The down side of doing that is you may have to charge it more often. Even then, it won’t be too often with a Fastwin. They start so easy, it doesn’t take much out of the battery. Besides, you will be surprised at how many amp hours they can pack into some of those small batteries. Compare amp hours to gallons. More amp hours, more "juice".
        EDIT: The question pertained to a Fastwin. I’d be a bit more selective if we were talking about something like a V-4 or 6 with electronic goodies.
        #13066
          No ends, or cables, yet…. The engine came without the boat side of the harness!!
          #13069
            It’s nice if the battery has wing nuts, but no big whoop if it doesn’t. They do make adapters. But then you have to factor in the adapters with the cost of the battery.
            #13072
              So a "U1" lawn tractor battery might do the trick?
              #13074
              hugh
                I have used a garden tractor battery on my "59 fastwin. Any of the smaller ones for me, light and easy to put in and out.
                #13075
                westwind
                  I’ve used a garden tractor battery as well. Doesn’t seem to be hard to start and worst case, the rope still works too. If you’re not keen on rope starting it might be wise to get a little bigger, just in case.
                  #13076
                    Easy to carry? Two small 6 volt batteries wired in series …
                    #13078
                    adam1961
                      Be careful with the lawn tractor batteries. The really cheap ones are just over a hundred amp and like to burn up starters. Use at least a 250CCA battery. I had a $40 battery burn up a brand new Kohler starter….bad day.
                      #13079
                        No doubt the more powerful mower battery will work, but just a little larger you can get a car battery with a whole lot more oomph. I currently have one in my boat. Not really feeling inspired to go out with a flashlight tonight to see what it is.
