I have a mid 70’s Evinrude 2HP motor that the idle needle threads on the carb side are damaged and I can’t screw the needle in. Can someone please tell me what size tap I need to chase those threads?
I looked all over and still can’t find that two horse carb but other ones from that era, such as 9.9 and an early 80’s 4.5 I found, have a 1/4 X 28 thread on the low speed needle. That’s a common SAE fine thread so no special tap or dye needed.
Thanks mumbles but I have a 1/4-28 and it is too course. I have a 4-40 tap that the threads fit and the shaft of the needle is 1/4″. I have never heard nor can I find a 1/4-40 tap. What am I missing?
I posted some special taps and dies used on OMC motors over on the Facebook site and a 1/4 X 40 was one of them. I had to order mine from a tool house in Vancouver. Grainger or someplace like them might be able to supply them or maybe on Ebay.
If you Google that size you should get some hits.
This reply was modified 4 years, 8 months ago by Mumbles.
