Home › Forum › Ask A Member › What to do with a spun prop hub?
- This topic has 17 replies, 13 voices, and was last updated 8 years, 11 months ago by
bgurney.
April 20, 2016 at 5:02 am #35115
I took this from a 1988 OMC Accessories catalog. One of the longer listings as they dropped props as time went by.
388294 AL 3 blade 9 1/4 x 7
389390 SST 3bl 9 1/4 x 9
379717 AL 3bl 9 x 9
389629 AL 3bl 9 x 10
592959 AL 3bl 9 x 10 weedless
388088 AL 3bl 9 1/4 x 11
389320 SST 3bl 9 1/4 x 12
This is a pretty long list from a Michigan 1991 catalog.
SMC39 3 blade 9 1/4 X 7 Closet OMC 388294
PJ12 3BL 9 x8
AMC448 4BL 9 X 9
EWC19 3BL 9 X 10 592959 weedless
PR20 3BL 8 3/4 X 11
PR22 3BL 8 3/4 X 12
PR24 3BL 8 3/4 X 13
PJ19 3BL 9 X 9 379717
PR26 3BL 8 3/4 X 14
PJ16 3BL 9 X 10 383629 also SS
PJ18 3BL 9 1/4 X 11
PJ15 3BL 9 1/4 X 12 also SS
AJC418 2BL 9 1/4 X 12 AJC417 BronzeApril 22, 2016 at 12:25 am #35210If slipping in the prop…I’ve seen screws driven through the prop into the rubber…just sayin..
April 22, 2016 at 1:47 am #35214quote rudderless:If slipping in the prop…I’ve seen screws driven through the prop into the rubber…just sayin..
Yup, that’s the old trick.It’s cheaper than re-hubbing and if you use stainless screws, this fix should last all summer long, especially if you are in salt water. 😕 Maybe all year in fresh.
April 22, 2016 at 12:12 pm #35229Typical 10hp props will have too little pitch to keep the RPM down on a 15.
I would get the prop fixed the right way. Trying to cobble something together will generally lead to issues down the line. It’s neither difficult or expensive to have it done properly.
April 24, 2016 at 1:06 am #35337Why don’t you contact Michigan propeller and see if you can buy a brand new one. I just recently bought a 7 pitch brand new for a 1955 Johnson 10 horse. I think at the time a 7,8 and 9 pitch were available.
April 24, 2016 at 10:16 pm #35429quote Billy J:Why don’t you contact Michigan propeller and see if you can buy a brand new one. I just recently bought a 7 pitch brand new for a 1955 Johnson 10 horse. I think at the time a 7,8 and 9 pitch were available.Well, right now it’s because I’m a little broke. 😆
I do need to see if anyone in the area has some of the different pitches, see what might work best for my boat
April 25, 2016 at 5:04 am #35449quote Mr. Asa:quote Mr. Asa:I do have a 12D10 and a pair of QD15s, can I use their props?Anyone know the answer to this question? I can dig up the part numbers on the props if need be
Yes, those QD props will fit on your ’56 Fastwin and they both use the same 203663 stainless drive pin. The major difference is in the pitch. The original Fastwin prop was 9 X 10 but the QD props are 9 X 8 so the boat should jump out of the water quicker but it won’t have the top speed as before. You also have to be careful to not over rev the motor with the QD prop on it.
May 10, 2016 at 3:26 am #36351I had Admiral/C & B Propeller Co in south Tampa re-hub the prop off of my 1958 Johnson 18 hp. They can handle just about any prop.
