Home › Forum › Ask A Member › What year is this Johnson?
- This topic has 7 replies, 5 voices, and was last updated 8 years, 7 months ago by garry-in-michigan.
September 14, 2015 at 11:50 pm #2538
Hi guys,
I just picked up an FD 13 R from a friend of mine. The model number is not showing up on marineengin.com. I’m guessing it’s a 59? Can anyone confirm? 18hp twin.Thanks, wannabe
September 15, 2015 at 12:19 am #23887Yup, my book says ’59. For some unknown reason, that was a bad year for marineengine…
September 15, 2015 at 12:20 am #238881959 18 hp see link for book
http://boatinfo.no/lib/johnson/manuals/ … on.html#/0
September 15, 2015 at 11:35 am #23906Thank you Guys,
If I can afford that much printer ink I’m going to print out that manual crosbyman. Might have to do it at work under the cover of darkness….September 15, 2015 at 1:08 pm #23912just copy it to your disk no need to print it ! it is a real good book with fine détails if you read it carefully you will find all your answers .
Don’t loose your job for "borrowing" your employer’s eqpt. ( been there… I use to work in corporate security and seen some sad cases like "borrowing" 5 gal jugs of water…for the cottage, borrowing tools and ladders. Every year comapnies loose millions in paer, erasers, liend paer pads, pencils, pens etc… at school time ! )
September 15, 2015 at 3:16 pm #23920quote wannabe outboard guy:Thank you Guys,
If I can afford that much printer ink I’m going to print out that manual crosbyman. Might have to do it at work under the cover of darkness….LMFAO 😆 😆
September 16, 2015 at 12:35 pm #24001quote crosbyman:just copy it to your disk no need to print it ! it is a real good book with fine détails if you read it carefully you will find all your answers .Don’t loose your job for “borrowing” your employer’s eqpt. ( been there… I use to work in corporate security and seen some sad cases like “borrowing” 5 gal jugs of water…for the cottage, borrowing tools and ladders. Every year comapnies loose millions in paer, erasers, liend paer pads, pencils, pens etc… at school time ! )
It was kind of a joke crosbyman, I’m self employed. The reason I would have to do it under the cover of darkness is my book keeper ( The Wife )
September 17, 2015 at 5:54 pm #24102It is a known fact that they sell the printers at a loss, but make a fortune on the ink. I got rid of a super accurate seven color printer because although the pictures were works of art, the refill ink cost almost as much as the printer. . . . 🙄
