Home Forum Ask A Member Winter Project
Viewing 10 posts - 1 through 10 (of 55 total)
  • #282316
    The Boat House
      Things are awful quiet here so I’ll add some
      content.
      I got this sad motor in 2016 in a “to by one you
      have to buy them all” deal. I had intended to
      just use it for parts but the stuff that it needed
      keep appearing. I don’t have everything but I
      will attempt the make, or repair the damaged
      parts I need, to complete this motor to use next
      summer. First will be repairing the coil mounts
      on the cylinders. This repair is essential for the
      project to move forward. Our Buccaneer has
      done this repair recently on one of these. I’ve
      also done some research on mig welding cast
      iron so I’m pretty confident I’can make this repair.
        Tubs, glad you’re going to give that “Pile of Parts”
        a second chance at life!
        That should keep you busy for a while.
        labrador-guy
          Whoa….Tubs,  you are gonna need a big sack of magic powder for that job!    It might take two winters but…. you can do it for sure!
          dale
          #282332
          bobw
            That one will take some work but it’s certainly in the hands of the right man for the job.   Keep us posted on progress.
            #282406
            The Boat House
              Took the best parts to make a motor and see
              what I’m missing. The only thing I don’t have is
              a prop nut, which is not a problem, and I need
              some spring steel to make the clip that holds the
              gear case up when its in the folded position.
              It was unusual warm yesterday for this time
              of year so I took it back apart and gave the parts
              their first cleaning.
              While I have all the parts to make a motor, some
              will need repair.
              fastjohn
                US Member - 2 Years
                It is not original, but I have used nylon lock nuts for prop nuts on a number of motors.  They never work loose and you can adjust the tension you want on the shear pin.
                #282409
                  It’s always nice to get to the phase where you can work with “clean” parts!
                  labrador-guy
                    Yes….Clean and inspected parts!   You are half way there.  The worst is over!   Is the old kicker stuck?   What do the cylinders look like?   Are you gonna grind the grapes off of the transom clamp?   I can’t see the tank very well in that pile of parts, no lumps/hills/divots to deal with?
                    dale
                    #282416
                    The Boat House
                      I was planning on using a castle nut.
                      I’ve done it before.
                      Using a nylock has never occurred to me.
                      I often use an O ring (rings) between the
                      gear case and the prop in an attempt to
                      slow the exit of the grease in these motors
                      without seals.
                      A nylock would be just the ticket for
                      adjusting the tension.
                      Thanks for the suggestion.
                      #282422
                      The Boat House
                        dale
