Home Forum Ask A Member Wizard super 10
  • #1822
    Dave Hostetter
      I have two problems with the Wizard Super 10 that I recently bought. One transom clamp screw is badly bent and the throttle lever is unmovable. Suggestions to correct these two problems will be appreciated. Thanks, Dave H
      Dave H
      #18614
      jw-in-dixie
        Can you remove (Dremel tool) the cup washer on the rear of the clamp screw, then unscrew and straighten it?
        Look on the rear of the magneto plate – see a screw (mabe two, I forget) there? Loosen the screw or remove it and the spring under it – apply WD40 into the hole and work the mag lever. That screw is a tension device to keep the lever from wandering when running. Old oil or grease is gummed probably and holding it tight.
        Good luck. JW in Dixie
